Dropping boost in mid climb last season.
Did a number of dyno runs today with SylvanLaker. So far no stumbles. Hopefully the issue is fixed.
Sled pulled pretty hard and put up some decent numbers.
I will start a dyno thread later but hard to beat the dyno when tuning and testing.
Put di electric grease on all the connections i could, changed the plugs and fixed wire on tvc control wire, new fuel filter.
Wont really know for sure until I start riding.
The dyno also takes clutches out of the equation so maybe I have/had a clutch or belt issue causing overreving.
Sled was also dry and not packed with snow so true riding conditions have not been reproduced.
I have a good feeling without clutches and dry setup everything seems to work.
Time will tell.
Friend of mine had same loss of boost. Turned out to be a broken copper donut in his exhaust header
Have had exhaust leaks before. Exhaust looks great. Sylvan laker sells a header with a lifetime warranty and no exhaust donuts........no more exhaust leaks :)
Took the sled for a test rip today. At the beginning seemed to be working ok but after 5-10 min and driving through very fine soft snow it didnt want to build boost at all. Kept sputtering when you would stab the throttle. I am guessing there must be some sort of grounding issue when things get wet. I am not really sure even where to start looking.
Ran fine on the dyno but add snow and it has a problem. Still need to pick up an AF sensor hopefully that will help diagnosis the problem.
Thoughts?
Alright Duke, I will pick up a set at Daves and see if the problem goes away. Strange that it works when dry on the dyno?
I had one that gave me some serious troubles. fought it for a while. Put it on a dyno @ Sea level (literally) and it pulled strong and solid. Went up in altitude and it ran like crap again. Tossed a new Regulator on and its been rock solid ever since. Maybe fuel pressure reg?
Best of luck
RS
Had an rx1 getting moisture in around the coil caps. Did the exact same thing. Took me forever to figure it out. Pull the coils and if they are wet on the bottom, bingo. standing water by the plugs.
Best of luck
RS
If it was the regulator why did it work at sea level? I assume it was giving random fuel pressure?
I will try some different coils this weekend.
8k this sled has run so strong with very little problems........this gremlin is becoming annoying!
Keep you updated. Thanks for the input.
Best of luck
RS
If i have to guess, after all the basic maintenance you performed, i would go straight to the regulator, next thing would be efi box.
vi-pec powersports
I have some regulators here you can try.
We stopped using the Malpassi regulators a couple years ago because they were prone to moisture getting in the body and rusting the spring.
We now use a small powersports regulator with a base of 44 PSI. It is a rising rate and works great.
Same here for our race nytros. Proven setup(we work with aeromotive style FPR). I had some problem with my personal 2008 nytro(impulse turbo) that used a BEGI fuel pressure regulator..the thin aluminum layer inside de regulator was cracking and loosing pressure, i was suffering from the same symptoms this gentlemen i suffering from.
vi-pec powersports
Sound good I will swing by the in the next couple of days and grab one. Any chance you can give the shop crew the heads up so if you are not there they know what to give me?
New fuel regulator and coils are on the menu.
Thanks
Paul
Thanks
Paul
Ok done.
Thanks
Just moved my sled and on top of things now i have an exhaust leak. I thought it sounded a bit funny yesterday but today it was loud like a tunnel dump and lots of exhaust coming from inside the tunnel. Plugging the exhaust makes no change except all the exhaust comes out the tunnel.
Will fix that while i am at it and see what happens.
Exhaust leak? Didnt you buy a new exhaust header last winter?
Yep not sure if its the header or bellows yet. Will take a closer look this weekend.
