I've been reading alot of the post on drive shaft bearings and took the plunge. Not to bad of a job so far but just a question. How do you get the speedo side bearing off of the shaft, is it pressed on? I've loosened the set screw on the collar and it does not want to budge. (btw-- the chain case side bearing has a small crack in it glad I took the plunge!)
Thanks
Thanks
