519000273
Here you go.
Here you go.
Man who uses credit card wisely fly free and get free chit, interest free no monthly fee ya followin me? Must budget wisely
You bought a $13 item with a master card?
....................................... You have to take your change and put it somewhere that won't fall out, that you'll remember, and that you can use for next time. I'll stick with the plastic.
Does not your Plastic credit card / debit card require you to remember where you put it, not lose it, as well? I don't see you winning many debates, with that logic. But hey the card companies are loving you for the percentage they get from every purchase you make.
But this is supposed to be about an Oil Cap not "Wise Financial Decisions 101"
ive been using the doo cap for about the last 5 rides due to me getting sick of bleeding the air bubble out of the oil line every couple rides. i cant comment on total oil usage. but i will say this. the air bubble is still coming back with the doo cap but it seems to be smaller and takse more time to show up. also on about half a dozen occasions when i have the side panel open i will crack the cap and listen, there has been a extremely noticable vacuum on the tank. or in other words when i crack the cap a lot of air escapes and you can see the tank return to normal shape. this only happens on maybe 1/4 of the times i have checked/cracked the cap. scary. so idk whats going on. i never had a problem with the polaris oil cap. (no motor meltdowns) but i never opened the polaris cap and noticed a vacuum on the system. i think im going to buy a paaso cap.
Can't find where to order the Paaso cap. Anyone have a place to find where to order it.
My buddy turned both of our oilers up just under two turns. We were runnin approximately 45:1 for several trips. We both went to the skidoo oil cap and I think he's running 30:1. I'm running 35:1 fairly consistently.
With Stock Cap
I filled the oil tank up to a certain spot (about 3/4 full) and used the stock cap. I burned a total of 10.5 gallons of fuel before filling the oil tank back up to the exact same spot. It took 36 oz of oil. 37.33:1 ratio
With Passo Cap
I filled the oil tank up to a certain spot (about 3/4 full) and used the Passo cap. I burned a total of 8.5 gallons of fuel before filling the oil tank back up to the exact same spot. It took 42 oz of oil. 25.9:1 ratio
