I believe the geo mod was intended for sleds without the fox float rear skid. Correct me if i am wrong?
Geo did two different relocations, one that relocated where the torsion spring slider was located on the 07's, and another one that relocated where the rear skid mounts attached on the drop down on 08 & newer. I can think of NO reason that the one intended for the float skid would not work on 09 & 010, the location or the rear bolts has not changed.
The float one moved the bolts forward & down slightly I believe? Can't remember.
Some keywords for future searching:
geomod, geo mod, skid, suspension, float, swingarm, bracket
http://www.snowestonline.com/forum/showthread.php?t=57103
i already read that entire post. i dont waste peoples time and i do my studying. nothing on 2010?
If you had done your research you would know that the part numbers for the suspension components are all the same for the years your concerned about, at that point we can all reasonably assume that the geometry is the same from one year to the next. The only variable I can see is the slide rails, but as far as I can tell the geometry remains the same. Or, since nobodys talking about it, you could just try it youself, and let us know if it works or not.
wyo, I think a lot of that is because of the higher HP machines & what we weigh.
I think if we were, for example, talking about a 140 lb rider with a 150hp M8 the situation with transfer would be a different story.
btw, 140-150 may be what fox calls maxxed out, but I know bigger guys running 180 & better with no issues. Find the proper sag, don't worry about the number.
I am this guy.ha..I weigh just a hair over 140 lbs, and have an 08 m8 with the 09-10 rear end/powerclaw that is tuned up to about 155ish hp. I feel like I have plenty of power, and in the meadows it flat rips, but as soon as we start climbing it treches something wicked. Skid is in the stock hole in front, and upper hole in the rear. I can't climb with it for chit...i can spank it on the hill with my stock m7 with a flipped/straightened A20..I'm also at a loss on what to do![]()
Are you getting too much ski lift on climbs?
Definately not, I have hardly any ski lift on climbs, or any other time for that matter...limiter straps are loose as they go. It hardly trackstands ever actually...which is fine. I'd rather it get on the snow and climb. but both would be nicebut i understand that you cant have the best of both worlds...just not sure what to do with it anymore..I thought the PC would be the cure..it helped..but still trenches bad in all snow conditions. I dont mean to highjack this thread at all...just stating my case
