DJ's clutch with RKT 860 XP?
DenverR1
I've got a DJ clutch kit and will soon have my RKT 860 BB done on my XP. What is the best clutch set up for this big bore. I also weigh 280 w/o gear if that makes a diiference. I know little about clutching but I'm trying...
Is your clutch kit for the 860? Or is it for the stock 800?
If the kit is from DJ and for the 860, you will be fine. If it is for the 800, I would contact DJ and see what you need to do with the current kit. You might be able to use it, or you might have to change out everything. I am sure you will at least be using different springs, and weights.
Yeah, it's for the stock 800. I was thinking the same thing about the springs and weights. Any ideas?
