Decent Smelling 2-stroke Oil?
What is your concern about the temp range in relation to Maxima oil?????
I've been told that the Maxima Castor 927 has a tendency to separate from the fuel at freezing temps. May be true may not be true but I would not want to take the chance since there is other great oils out there that won't separate in freezing temps (Klotz Technaplate, TORCO SSO).
P.P.
P.P.
I recently brought this exact problem up in another oil thread. I was interested in the good qualities of a Castor based oil, but some of the more knowledgeable people advised against it for these same reasons. It doesnt do well below 35 degrees or so.
Ok, thanks for all the replies. Spent some time on the phone and this is what I found:
Spectro oils. Very nice, professional salesman. Told me Spectro is quite neutral and would have little to no smell at all, and no smoke. He had me call Performance Northwest, one of their distributors, and speak to "Eric". He told me the same thing. Eric also told me ELF is thinking of brining out a snow specific oil that will have the righteous smell of castor. They do have it now, but it is in a hideously expensive, retro-style quart can on only a limited production basis, pretty much for collectors, but were there enough demand for it, they may swing into production.
Redline oil. Jerks. Condescending salesman told me "we don't make oil based on exhaust smell". Right. I attempted to explain I know once a certain level of quality is reached, all the oils are going to be pretty comparable and give me what I want, why can't they make one that doesn't stink? No answer.
Maxima. Very nice, professional and a sense of humour, the guy knew exactly what I was talking about, but wasn't able to comment on odor of the various Maxima oils due to so many variables. He did agree castor was the best smelling, but as has been mentioned, it will separate once temps hit +35*F. The salesman recommended their Tundra R 50% petro oil.
I did not call Blue Marble yet, and will call Blendzall tomorrow. Will keep updating.
power plus by manhattan oil is the best smelling or i can sell you some fuel fragrance 20 different flavors.
both blue marble and redline smell good, the XPS carp should be banned......smells like dead camel sex
Blendzall Ultra
I contacted Blendzall about their castor oil. Our fellow forum user OregunRMK has been using it the past 2 years with no problems or VES valve sticking. This is the response I got back from Blendzall:
Wayne,
Ultra #455 is a pre mix and injected oil. It is castor based and works great in snowmobiles.
It was tested in Canada at -20. It has a rust inhibitor. Be sure to clean you tank out before
adding castor or any other oil to your old oil. NEVER mix any oils together. If you have any
questions, please e-mail.
So, I ordered a few gallons to try out. I'll be switching our sleds from Polaris VES gold. I found a great deal on the oil here: http://www.onoffroad.com/Merchant2/...Code=ULTRA&Category_Code=BLENDZALL-LUBRICANTS
Wayne
Dumonde... hands down!!
Redline... very close 2nd!
Doo syn stinks.. I have to ride in the rear because of the headaches
Yup, called Blendzall and they told me to go with the 455. S I called Performance Northwest and ordered two gallons of Spectro SynSno and two gallons of the 455 castor. Can't wait 'till they get here.
Just mix up about a 1/4 tank of vp 110 race fuel with your pump gas. Or if you can afford it and you run a high comp motor run a full tank! Cant beat the smell of this stuff. You and your buddies will be huffing exhaust fumes non stop! You will also know your running a safe octaine # (you get bogus octaine levels at the pump). :beer;
If you have ever been to a race or a hill climb event the sweet smell in the air is not a certin brand of oil it's the race gas.
Legend is the best i have seen (smelled)
It is a little hard to get, but not too expensive.
