Cvt snow bike
etec would be ideal if you want to ride for most of a day. wouldnt want a sled sized gas tank on there!
awsome build
Weight and engine size
I agree.
What about cats 500 or 600cc engines.
Are they lighter or smaller?
What's Cats new 600 like on fuel?
It makes pretty good power.
I agree.
Are they lighter/smaller?
Can't beat the eteck for fuel economy reliability size and weight. Possibly the best all around 2 stroke engine ever build. It just hits the sweet spot on so many aspects needed for sleds and snow bikes.
As I think about this, wouldn't it be easier to Fabricate the MX chassis onto an existing snowmobile chassis?
Sleds are too wide to build off of. Even a firecat has a 14" wide tunnel. Although you're gonna make me take a second look at the firecat chassis I have sitting around :)
A poo or doo tunnel being in long pieces you can just derivet and narrow the strips, then rerivet.
I've got a 09 poo 800 163 sitting around I should chop up.
Could sell the body and front suspension for a couple bucks.
no way.
end up like a like a fat pig snowhawk.
Not so much. The snowhawk's engine is too far forward, and the rider is still sitting behind the engine.
If someone fabricated the MX chassis to a snowmobile chassis so that the snow engine was in the location of the MX engine, the riders position would be above, or just ahead of the snow engine.
Sorry for my horrible photoshop skills.
^i see what u mean now. thought you were talkin narrow a sled chassi and put forks on it and all that..
using a sled bulkhead that the motor and tunnel mounts to would still make it too fat i think.
back to the o.p. sorry
Main problem would be pistons leaning to exhaust side of the cylinder.
The reason why there are many small intake ports and one big exhaus port is that the piston needs enough support to slide down under power stroke.
It would work with reverse rotation for some time but not long.
http://www.marinediesels.info/Theory/torque_2.gif
What about flipping cylinders around? I have a buddy that builds crazy two stroke street bikes, he has done this a couple times with air cooled twins. The bolt pattern on a ptech looks like it would allow this. Would really like a solid answer on why it wouldnt work.
Cheers
I also have my sled/bike starting to go together, 154x12.5x2.25, 800 p-tek, cr 450 frame, it is looking sweet!
And will be for sale when it's done!
Sorry for my horrible photoshop skills.[/QUOTE
Feet and Knees would be in the clutch and drivetrain. The only way to make a comfortable rider compartment is to move bars back, linkage to forks and pegs back= snowhawk.
The only way we have been able to make it work well with a cvt. Unless you put the motor behind your legs like les did here. Nice work!
Cheers
If you flip the cylinders you are back where you started. Exhaust pointing forward and intake to the back. Only now you have waterpump and oilpump turning the wrong way and clutch at your right.
If I would use some snowmobile engine I would take the clutch out and put chain or beltdrive between the motor and the clutch. Clutch would be better located at the same side of the belt as the motor. That way it would be some 200mm/8" less width and more cenralized mass.
