Very good questions. Thanks for asking. c3 builds a very nice kit for the cost. Problems that are not addressed with just a simple sprocket and belt kit are: The brake remains on the top shaft which when applied puts a severe reverse torque load on the teeth of the belt. I believe this is part of the teeth stripping problem on the qd system. It also transfers a lot of heat into the shaft and the bearing on that end of the shaft which will cause premature failure. The brake on the CMXDS is on the bottom, so the belt doesn't see the effect of the brake. The only reverse torque load our belt sees is engine braking when going down hill. The CMXDS also relocates the driveshaft down an inch and back an inch from stock location, which give you a better attack angle which helps your sled get up on the snow better. It also will allow you to run a 3" track with full sized drivers. Huge advantage over the baby 7 tooth drivers. There are several other advantages to the CMXDS, but I don't want to make this too long. We started the CMXDS in 1999 and did not want to make any compromises by designing it around any stock parts. That is still true today. The cost of the CMXDS is a bargain for what all you are getting in the kit, and if you can afford it you will be very satisfied. Thanks,
