WOW ???? membrane???? WTF???
The only part of this that is somewhat correct is "making the roller work harder"
The only similarities between the adjustable cam arms, and the TRA clickers, is that RPM's can be adjusted with both fairly easily. While both change RPM, they are not doing it in the same manner. One is changing total mass effecting RPM (cam arm), and the other is altering ramp profile to change RPM (TRA).
In order to have the exact same effect, you would need to be adding or subtracting mass from the pins of the TRA, as you add or subtract screws from your cam arms... IE... changing MASS!!
If you wished to change the RPM in your "Comet Clone" (p-85, Cat, Yamaha) clutch, in the same manner as the TRA is altering RPM, you would have to grind on the roller contacting face of the cam arm. Thus changing the "Shift profile" of the cam arm, effecting RPM.
