finished product
This weekend it was almost 50 degrees on the pass. I really noticed my charge tube temps were pretty high. The highest I saw was 206. Thats no good. So I came home and decided I would go ahead with the cold air intake build as the temps stay warm with the onset of spring. I went down to the local O'Riely Auto parts and got everything I needed.
I decided to go with Spectre polihed aluminum (SUCKER FOR BLING) 4" intake tubing. They offer a 3" plastic version but I figured it would melt being close to pipe but I could be wrong.
Parts List
1 90 degree 4" elbow
2 strait intake pipes 6" long each
1 cone air filter
1 reducer- 4" to 3" (comes with 2 clamps)
2 couplers (each come with 2 clamps)
TOTAL COST $115Although only one strait pipe is shown I used 2, same for couplers
Here is the mounted intake
And with the hood closed
To answer some obvious questions....
* Yes, you do have to remove the air filter on the top to open the hood. It is only 1 clamp so no big deal.
* There is a prefilter available from K&N or Injen Technologies. Both were under $30. I am ordering the K&N.
* I cut the hood with a hole saw to begin with and finshed up with a skill saw to make everything come out nice and clean.
I have not ran this on the snow but anything has to be an improvement over the under hood heat. I am expecting t least 40-50 degrees (Jeremy mentioned this range in above post) drop in charge tube temp. Should work great in the spring warm!!!!!!! Will let everyone know how it goes tomorrow after first on snow testing. Project took just over two hours to complete
