CMX
Hey guys...This is not a picture of a CMXDS installation. My guess is that it is Avid's extended chain case. Our system only requires a very slight trim with a die grinder on the PTO side to remove about 1/16" of material. This picture shows a bigger mod to the stock chassis. See picture below of the CMXDS install. Very little mod to the stock chassis and easy to reverse. Thanks,
OURS
AVID
What Rick! said...
In this pic of SnowDawgs tunnel... you can see the new suspension location mounted back and down from the stock location...This is typical to the install.
If you don't, the inside fo the track will rub on the upper cross tube of the front swing arm... it is pretty close when stock... move the track down 1" and you will see what I'm talking about.
OURS
