Commenting about the CMX only....
I will try and get better pics tomorrow in the light, that's how far out the the brake caliper sticks through the foot vent with the cmx belt system. Not hardly any.
I installed the cmx belt drive on my '13 pro after ripping all the cogs off the stock belt within the first 100 miles and then having to take another 100 miles to break in another belt I decided it wasn't something I wanted to wait for. The cmx belt has no break in time, you install it and ride it like you stole it. I think the cmx belt drive is more efficient that the Polaris belt drive. My wife has a 13 pro also with the stock belt drive and pulling the two sled out of the trailer or garage you can easily tell the resistance on the cmx belt drive is my less. The cmx belt drive is a pretty good way to go to fix IMO the weak link of the 13. You don't have to run a collar on the track shaft, because you get a new shaft. And you get a much stronger belt along with a tensioner. Different gear ratios. You can change the belt on the hill, if it ever did break, without having to have the alignment tool needed for the stock belt drive system. The brake is on the bottom shaft so if you do break the belt you still have a brake. And to top it all off Mark at cmx is outstanding to work with.
