It is a sticky, and it does try and explain what each thing does. You just have to read it from the beginning.as for this thread for the dummies like me maybe somebody can make a list of some sort exsplaining what each thing does and how it affects the sled and maybe make it a sticky.
mods, can this get cleaned up for theory only?
Very valid point though, and good reasoning for cleaning this thread up.
Agreed, it is a valuable question, sorry, I wasn't trying to single you out, just noticed the thread direction has changed since the beginning. Again, not trying to single you out, timing is all. I happened to be looking through it and you were the last person that posted.i think .46 to .36 is a valuble question, i was just useing my sled as an example. i still think somebody should gather this imformation put on one page instead of scattered thru 3 or 4 pages once this "theory" page is ending
Its hard to stick with theoy with out using examples,
So when it comes to the secondary things get alittle harder due to the fact
from brand to brand they vary in how they work, the winding of the spring vs some of the new ones that just use compression.
I found the link spiderman posted that showed the lb of force on the belt from the secondary with diff springs and helix's very odd. it did not go up in lb of force with the flatter angles like I thought it would. So here is the question, I understand you can have to much grip "force" in the secondary but what do you do when you are not getting GOOD back shift. ??? just dropping cam weight makes sence but at the same time that will effect the speed of your shift, even taking weight from the tip of the cam will help but not enough, So whats the theory on "tuning" a perfect shift someone must has a bit of a step by step tuning the clutches. Myself Ive always enjoyed and have had good luck with clutching many machines until this one right now has me guessing. Im under the belief the CVT it the perfect clutch but when your having a hard time getting close to perfect,,,,,,,,, I will watch for someone to post some knowledgeable tuning help. IMO clutching for drags is easy, clutching for top speed is not trying to get the best of both worlds is even harder.
How much spring force on the start and finish of the secondary spring does 1 delrin washer add? Does that number double and triple when you add 2 or 3 delrin washers respectively? I assume its minimal, but might change some when you have 2 or 3 in there?
Clutch alignment question. I've figured out that my jackshaft flexes enough for the secondary to move about .250" forward under full load. What's the theory on how to line up the clutches while planning for that kind of deflection? Standard 1" jackshaft with a .200" spacer between the bearing and the clutch.
I have never heard of a jackshaft flexing....at least not a measurable amount, yet 1/4"!! That's huge and something is seriously wrong if that's the case. Everything related to the jackshaft should be solid.
The engine does move alot though.
I do alignment the same on any sled with any combination of clutches. The belt should just kiss the inner sheave on the primary with all belt-sheave clearance to the outer sheave and no visible "dogleg" in the belt. C-C set for belt length and belt just above the secondary sheaves.
