Has anyone heard what the setup should be for the 09' 154" w/SLP y-pipe, pipe,& can. Also when you add there head w/domes for alt.8000' up. Checked the website from time to time, nothing updated last I checked.
T/A
Can you price me a head, pipe combo
I want 8-10k head
How was your ride today
I am headin out to ride in about 30 min
just got home 41 miles of rode ridding sled acted very wierd
Knock senser went off 3 times at 10100 feet
Sled was so rich it fouled plugs
not sure what happend havnt changed anything
everything still stock last time was reving 8250 now only 7500
hollow pins in click 5 topped out at 86 mph last night
that was on hard pack
in 1 foot no track could only run 50 at 7400 rpm
The sled kept having engine light on and saying detnation but only at 10100 feet down lower didn't go off. Sled runs like it is choked now. Ran out of gas at 41 miles. Pistons completly washed off plugs wet.
running short hollow pins still to heavy for stock set up
works ok on road turning 8200 but in 18" snow only 7900
am going to go to some aluminum pins and load them to 11 grams hopefully it will pull that
So the current setup is #490 jet w/pipe, #500's w/pipe & head.
Primary clutch running stock spring & ramps, but shorter hollow pins (10.9 grams)like in the 08's.
Secondary running stock spring & helix?
If not, what poundage? Stock start & heavier finish?
my neighboor is running there kit... head, pipe, can, v-reeds and he is at 500 mains which is 2 steps higher than stock. He is sponsored by SLP and he says the don't have a lot of field time on the kit.
OT
