Thats NOT been balanced...not one drill hole..‘22 850 na clutch recall done, looks like it was balanced.
Mine won’t let me just bring the clutch in…Curious as to what happens to the P85 clutches that are part of the recall, but have been lightened and balanced by Patrick's / TJ.
I assume Polaris wants the old junk back. I'm fine putting the original cover back on, but I wonder if the dealer will take one look at me with shiny lightened clutch in hand and immediately point me to the exit. Anyone have this discussion yet with a dealer?
There are not warrantee issues with our lighten and balanced clutches...Polaris Engineering has many of our carbon fiber covers and lightened and balanced clutch on many of the Polaris engineers desks...So many tests have been done on our Lightened and balanced clutches all confirming the longevity and performance gains...We talk to Polaris weekly about numerous issues...If anyone runs into a issue have them contact us please...www.patrickcustomcarbon.comCurious as to what happens to the P85 clutches that are part of the recall, but have been lightened and balanced by Patrick's / TJ.
Yes....that is exactly correct...all anyone has to do is look at the clutch you bring in (old one)and see the holes in the cover and the fixed sheave....the less holes the less probability they are balanced as close as the stock old one...Great analogy. thanks!Question for TJ at Patrick Custom Carbon.
To me it sounds like the clutches that Polaris is sending out to replace the recalled clutches are balanced as long as there are balancing holes drilled in them. From what I understand from reading this thread is that even though Polaris has balanced these clutches the balancing spec is nowhere near the precise specs that you guys balance them to. My assumption is the clutches are fine to run but if you want less vibration, cooler running, better performance and longer life you should send them to Patrick's for a precision job. Am I correct here TJ?
Is there a roller bearing on that p85?just got mine yesterda, belt to sheave clearance was so large I was able to use my 47r belt I got from TRS Tony last year without having to re-shim. Got .012 clearance with the 47
tldr: belt to sheave is still way off gotta check every one
No roller bearing, sleds a na 850. Ya changed belts to make it right. was running the 45r last year. just got lucky that I had a 47 on the shelfIs there a roller bearing on that p85?
Did you have to change the belt?
