ot)riding constant deep powder and the load associated with the deep snow condition will also contribute to clutch heat even when the clutching is perfectly tuned
Joe)Thank you for your astonishing disclosure.
Then knowing the principles;
The #1 cause of system heat is fluctuating rpms.
The #2 cause of system heat (even when rpms don't fluctuate) is too large of helix angle; belt slip in the secondary.
if the rpms fluctuate or helix angle too large,
regardless of load value then the temperatures will be higher .
regardless of venting then the temperatures will be higher .
regardless of if you added external cooling features then the temperatures will be higher .
Regardless of load or cooling enhancements, these details are basic to conclude.
