Years ago when we were running big bores and Garret's on triple XLT's , 780 and 670 Doo's we did everything we could to brace the PTO side trying to prevent both the motor & the CVT's from jumping around...The trouble than became where will the engines natural harmonic vibration go next ??? Back then which i still believe holds true today Crank, Jackshaft & Chain all need addressed especially in today's lite weight sleds and OEM stamp out parts....Theres is a machine shop we used to use in MN. that made heavy duty balanced jack shafts which I highly recommend if your running big power in today's sleds...Than I suggest like many of us already know replace your gears & chain with HYVO I'm not sure I would use the belt drive system especially over 200hp. Besides you can replace your entire HYVO 4 to 5 riding season for the cost of 1 belt drive kit.....Pull your crank and have it balanced there are even machine shops that can beef up your stock crank or if $$$ are no object build a billet one....Than finish everything off with bracing.
And hang on the power to the ground is extremely noticeable, the heat between the sheaves will drop resulting in optimum performance from the crank, to the drive, to the driven, to the jack shaft, to the chain case....also get rid of the stock drivers and install some Avids
People spend a lot of money buying clutch kits but seldom do they or there supplier address outside components critical to clutching performance.
DPG
