Ok so last night I unloaded the new used (600 miles) 2013 RMk 800 Pro and took the trail ten miles into Cooke City. Sled ran fine for the most part. I could tell it was idling a little weakly and I figured that was because the belt was too tight, which it was, cause it tried creeping on me a few times on flat ground.
So this morning, I go to start sled to pull it in the shop but it wont start. I had to pull a lot harder than usual. Took the belt off, and gave it a pull and it fired up right away.
Sooo, i monkeyed with the belt tension adjuster on the secondary a bit. Even with the belt sitting 1/8" IN the driven clutch (i usually about 1/8 OUT), the sled would still try move when rotating the primary by hand. What could cause this to possibly be so grippy/tight? I took the clutch off to check the side clearance, and there is a solid 1/16"+ of side clearance. I plan on tightening that up a bit right now, but I don't understand what would make me have to set the belt so far into the secondary for it not to be gripping the drive clutch.... thoughts ideas?? Im using the Polaris 115 belt.
Taking the clutches inside right now for a thorough cleaning and degreasing as well as switching weights.
