check engine 10 times HELP!
K
kyten
New member
My rmk 900 -06 166" got problem. It goes very bad. The check engine flash 10 times. I have checked stator, cps,ecu, injecktors and tps. All thats is ok.
HELP!!!!
HELP!!!!
If it's like mine the wire harness to the hood can get hot enough near the exhaust to melt wires. I got an '05 900 166 for very little because the seller didn't see this...I spent more hours than I would like to admit re-wiring..but I wasn't too busy anyway..You may have to pull the pipe to get a good look at this harness, I did....good luck:face-icon-small-coo
ECU is not seeing the signal from the 5 tooth cps...pull your stator and see if it came de-laminated and clipped the wires. I just replaced my stator, but kept the old one becase those sensors were good.....there yours if you need them
If you have done ALL the checks and still have not found anything, take a look at the 5 tooth tone wheel to see if it has turned on the fly wheel. Mine had done this and all I did was tapped it back into place and had a welder spot weld it in place. It still is running good. I can't remember the exact spot it is to be located, I had to check on my buddy's 900 to find the exact location. It took many hrs, many many beers, and many tear down's and reasembly's to find it. Good luck.
