yup, did the same think on mine. well, at least on the dragon. the pro got 8 tooth involute drivers and a PC. that whole center driver thing was the biggest POS thing polaris did. pv
yup, did the same think on mine. well, at least on the dragon. the pro got 8 tooth involute drivers and a PC. that whole center driver thing was the biggest POS thing polaris did. if you actually run your track close to factory tension you won't ratchet. i often ride in heavy wet snow and i NEVER ratchet. it's been so long i've stopped thinking about it actually. and don't forget, just b/c you can move your sled around in the garage easier b/c you loosened your track does NOT mean it performs better on the snow. quite the opposite actually. proper tensioned tracks are better preforming tracks regardless of what drivers you use. lots of discussions on this in other threads
pv
So I have had a pro for two seasons now and have basically on been sledding for 3 years. I am still definatly learning the ins and outs of proper sled setup as well as tricks and tips to solving common problems.
Could someone "dumb this down" a bit for me. I'm not exactly sure what part of the track system your talking about and what the problem is. I keep my track tension on the looser side of the spec (3/4" or so)
Hey so when your talking about "ratcheting" is that when the track skips on the drivers?? I haven't noticed that yet.
