Compare to 9R Khaos 155x3"?
Just put a turbo on the right side and a light can. That is how to balance the sled.It may have something to do with balancing the sled side-to-side, making it easier to get on edge on the right side. I know I've heard that theory before, and it seems more plausible to me. Did something change with sound levels around 2015? I still run the stock can on my pro; it only weighs around 12 lbs, and it's not noisy. I've been told - and my own research into cans agrees - there's not much out there that's lighter, not noisy, and doesn't lose power. The Axys can gained a ton of weight (it's over 20 lbs), but I haven't noticed it being much quieter.
Given how sled manufacturers chase weight numbers (for good reason), it's just hard to believe they couldn't come up with a can that passes the feds' sound test and weighs closer to 10lb, not over 20. There are plenty of reasonably quiet cans out there in the 10lb range; I just don't see why you'd need that much weight to make it quiet enough. I could be wrong, but even if they came up with a magic weightless silencer that costs them $5, it's possible they'd just build 15lbs of ballast into the right side because the average rider would prefer how that handled - despite the unnecessary weight. I guess I could test that theory by throwing 10lbs onto the right side of my sled! But then, if I liked it that much, why make it dead weight? Maybe turbo sleds have more of an argument going for them...
Snowest’s 9r khaos 155x3.25 pidd gauge was 520 rtrCompare to 9R Khaos 155x3"?
Mountain sledder garage just did a video and they were within a pound of each other. The Polaris holds more fuel though.From some videos I've seen, the Mountain Cat Alpha One is coming in 10-15 lbs lighter than Polaris. Minimal, but worth mentioning. At least it's a lot lighter than they were in the past. When moving my Catalyst around in the trailer, it feels pretty much the same as my Khaos. My King Cat is a lot lighter in back but a lot heavier up front. Gee, I wonder why.![]()
15 degree approach angle and 7 inch driver and 10 inch rear is probably why the 600 did so well in the deep and steep, sled is going to be a blastMountain sledder garage just did a video and they were within a pound of each other. The Polaris holds more fuel though.
9r holds more fuel I’m guessing.A lot different then the 150s weighed in the other video. Why?
Can't be much more.9r holds more fuel I’m guessing.
The sleds aren’t bone dry. Both picked up from the dealers and haven’t been ridden. Both have fuel light on but had enough fuel to drive out the trailer and off the deck. Never have known the dealer to put more than a gallon of gas in a sled. Regardless the important number is the difference in the two. Who knows made the 9r had more gas than the 858?Can't be much more.
His dry weights (no fuel, no oil):
Pol - 424.4
AC - 429.4 (AC's listed dry weight is 424 so right in line with coolant capacity)
His ready to ride weights (full of fuel and oil):
Pol - 497
AC - 499
His AC ready to ride weight is right in line with several other posted weights. I can't speak for the Polaris weight, I honestly don't pay any attention to those sleds.
I guess maybe there is an additional 15lb difference with the extra track length and shock packages? Outside of that I do not know what it could be other then the sleds had some fuel in them.
Maybe I'm missing something in the video, but the pol is 448 and the 858 is 468 - showing the 858 is 20 lbs more? Just seems like they should be closure in weight from what I've seen here and on social media.The sleds aren’t bone dry. Both picked up from the dealers and haven’t been ridden. Both have fuel light on but had enough fuel to drive out the trailer and off the deck. Never have known the dealer to put more than a gallon of gas in a sled. Regardless the important number is the difference in the two. Who knows made the 9r had more gas than the 858?
Maybe I’m missing something. Seen other social media claiming the same results I did. These 2 sleds are the closest I’ve seen that are almost identical packages. The biggest difference would be the 2.75” track is lighter on the 9R than the 3” cat track. I have no skin in the game which sled is lighter, just posting results that are pretty accurate on the difference between the 2 sleds.Maybe I'm missing something in the video, but the pol is 448 and the 858 is 468 - showing the 858 is 20 lbs more? Just seems like they should be closure in weight from what I've seen here and on social media.
I put 2 gallons in at the shop when I built it and filled it on the way to the mountain. the pump shut off at 7.8 gallons. Probably could have squeezed a bit more in there but let's say right at 10 gallons.So has anyone checked how much actual fuel these things hold?
