Oh Ic, I didn't realize you aren't running Carl heads. I am just trying to keep the info clear for the next person looking, not alot of info to be found for these motors on the net.
Im running carls domes but the set thats in the sled is cut to make the compression 15.5/1. I have the 15.5 domes 14/1 domes 50cc and 55cc domes now.
To my knowledge carls offered 47cc 50cc and 55cc domes for this engine but made several other varying compression level domes for this engine back in its time.
You right there is not a lot of info. Mine only runs the way it does because I patched together the little bit of info I actually got from Carls, the info I got from a couple people here and made some educated guesses as to how this sled should be tuned. I got ballbark this year for flatland and right on the money for elevation.
What I know based I how my engine runs is it likes 8300-8350 RPM's. The previous owner told me 8200 but I put an actual know calibrated tach on it and it wasnt clutched to hit 8200 anyway.
This engine seems to be more based on torque than over all HP. It makes good HP but the torque is what is the most impressive part about it. I can litterally fully let off the throttle going up a climb, stab it again and tractor right on up.
I can climb things now with zero run that I had to get a sizeable run at before, makes riding in the trees really fun. Another thing about this engine is that it loves fresh air. The more you can get to it the better. I think I will be going to a mesh hood to ensure that I dont heat soak. When riding in the tight trees a couple of times with the hood on my pipes heat soaked and it took a while for the sled to come back.
I forgot to mention I run the XCR style remote thermostat with scratchers, highest i;ve had my temps get is 135.
