You're going to take out a rod bearing if you keep riding it with it detonating.
Double check your ignition timing (probably have to call Carl's, as it might not be the factory spec), and check your TPS voltage. Look up how to do this, there is a good video on youtube. You can use a USB cord for your 5.0V supply voltage.
When you take the head off, look really close at the pistons. Are there any tiny craters in the dome? That's indicative of detonation.
I had my det sensor mounting bolt fall out once, temperature light was flashing, bolted sensor back to head and all was well. Might as well put a strip of silicone on exhaust springs anyway.
But don't ride it if its detonating. It seems you have it backwards, if anything you want to run MORE race fuel than you have now. Don't "start" over and run straight pump gas.
Running on a stand I doubt you'd see deto. You need to load the motor to test, and a free spinning track isn't load.
