Yup, disconnect the TPS. Get a micrometer and check either the timing marks on the flywheel or idealy mark the clutch with a new mark (Check out the SLP how-to, its aweseme). Then check it at 8100rpm. Set it to what Carl's told you.
If you have the reprogrammed CDI you will find it is 4 degrees advanced with the key in premium mode. Again, SLP's guide gives you good info on how to accomplish that.
sled_guy
Thanks sled guy! I got contacted by Chris from Carls again today. He wants me to set it to factory specs 1st at low RPM, he says all of Carls settings are for 8k elevation and up!
How ever i have made some progress on the sled today (keep in mind still waiting for friend to show up to help check timing he has the timing gun and tools to do it). See remarks for my progess:
-I have removed the 550N main jets and found that 560 are actually larger. I do have a few larger main jets on the way.
-while removing the Carbs i found this Image DET Issue i bent it awat from motor
-I have siliconed all the springs and exhaust fittings
-Removed all the gas from the system and put in fresh gas that should be at 101oct 2.15gals of 110 and 3gals of nonE 91oct
I went out back and made 2 ~600' pulls see old plug images, they cleaned up well and turned from yellow to slight brown
I then installed fresh plugs and did 3 ~600' pulls See "New images"
Also while doing all this the Temp light never flashed once! I made around 7 600' pulls all together. Still want to check timing but i'm not holding my breath on it just yet. Based on new plugs, seems i need to go up 1-2 sizes on my main jet and maybe even my needle jet which is at #3 notch.
