I have a 910 with twin slp pipes, that i put into a 01 600 edge chassie. I am haveing some temp issue's. On trail with ~1" loose snow it runs hot 170-180, if i get into deep snow it will cool down too 140-150, once out of deep back to high temps. At idle it will climb 200+. I have checked for air and will put back on tilt trailer again to check for more trapped air.
I also have done/current setup:
Domes have 6cc (were 50cc now 56cc) removed to lower Compression for pump gas and elevation
540N main jets
Needle on #3 mark
Air screw 1.75 turns out
When i bought the motor online i noticed the thermostate was missing did carls have ppl run them without one? My though was it could be circulating to fast and not cooling correctly without one?? Last question, the "cold line" on coolant bottle should that be level with the top of the head cover? If i recall correctly on my 600 it was and with this being little taller motor it sits below, so this is were i could be collecting air????
I have also pinched off some not all way, line that allows coolant to flow driectly back into the return line some. this did seem to lower it some more. Was thinking it may be flowing to much coolant back thru to motor and not the system to cool off??
Thanks in-advance for any input!!
540N main jets
Needle on #3 mark
