Dynamically Venting the sides to a pitot is JUST one way to do it..
In the case of the oem flatslide like yours you could go that route or a bov from powderlites,, very nice unit.
The only issue with a BOV is venting it away from clutchs and soforthe.
bowls will always be vented to airbox for a static signal.
oil pressure for a ball unit will be very very low, Twister has a nice small unit .
Shane uses the oem injector pump to supply oil on his sleds..
ball units just need oil present NOT under high pressures as a plain bearing would need..
Gus
Gus
