I know most in here are talking about the Doo's. Im curious to see if anyone has a "Kit" available for the Carbed Cat's setup and ready with all that is needed to install... I have an 05 900 kingcat.. I have SLP pipe and speedwerx heads. Would I have to replace them to turbo it? My 900 runs very well but I want turbo.. lol..
Sorry for the confusion turboxp. What is your tuning like on the aero setup?? What kind of boost??
Jake
I run 10lbs and as far as tuning it is not bad you just have to be happy with just about perfect don't go for that little extra or you will have problems.
Have had more problems with the xp than the rev but that has alot with me pushing the envelope.By the way Dave sweet looking turbo set up you built for the xp.
GLENN
Hey Gus,
I've got a big bore twin cat. Kinda tossing around the idea of running a low pressure setup to get some sea level HP at my elevation 7 - 11K ft. I read and hear about porting being the problem. With out giving away the farm is there some port timing data available for optimum?
I'm guessing that the milder porting the better for big boost, but I'm going to try to stay on mellow side so I can work with what I got.
Thanks,
Tony
PS very cool thread.
Hey Gus,
Thanks,
Tony
Tony what big bore cat are your eluding too ??
the port timing on any engine is NOT always an issue.
many times unported big bores perform better than retouched ones WHEN under boost.
Excessive blowdown TIME is a sticky culprit for most aftermarket kits from the past. Up to date kits may not be an issue..
gus
Hey Gus, I'm running a cutler 1000 on an M7 at 8050 rpm. I've been told that this setup doesn't turbo well. I assumed it's because of too much port open time, but I have not degreed the ports yet to find out what it is.
I canned the EFI a few years back in favor of a set of big cutler carbs. I'm assuming that I would need to get a stock set of 40s for the turbo.......or do you like something else better?
Even though I run low compression heads I assume that I would still need to lower the compression.
Another assumption (I'm full of them) is the timing key(2 degree) would have to go or even turned around retarded?????????
What are your thoughts?
Hey Dave, Not busted yet.......I'm researching and thinking out loud. You don't have to worry about me just yet.........course when did you ever...LOL
That motor is a finicky summm beaatch.... I would be careful. Guys have ended up in the mental ward trying to get it to run with a turbo. IMO, you be ahead by selling the motor and buying a stock 1000.
That said anything is possible.......
What do you recommend for an oil pump. I see by a previous answer that you recomend 30 PSI. Is that to a restrictor orifice in the turbo?
