C
canucklehead
I ran a set of cutlers 48's on my old bigbore and I never found much use for the lower powerjets.
I only use the midrange one. It does help add to the needle, but the lower one seems to be a waste. I often wonder, since they share the same supply tube, if at part throttle if the vacumn/draw on the lower one wouldn't pull air from the mid instead of fuel from the bowl.
Tony, you are correct. the common feed is the problem.
its much easier to pull air than liquid. hence the mix would be leaned not enriched when using both of those common feed circuits.
A carburator is a siphon,, no more technolgy than that.
I now have a set of said 48 cutlers to work with,, lots of little leaks and stuff to clean up..
Gus
If I understand your question and the functional operation of the powerjets: The jet can not draw from another orifice propelled buy the same systemic energy. Don't view the fuel as being drawn into the carb orifice, yet see it as being pushed... From a diiferential of pressure. Only way would be if the pressure head at the throttle blade were high enough to counter act the lower pressure differential at the bottom....
The bottom one doesn't seem to matter is, in my view, because the main circuit is already saturating that portion of the air mass that any additional fuel introduced in this area of the carb orifice would simply be prone to falling out of suspension and puddling.
This would impact detonation tendencies under high preceeding combustion temperatures in the chamber, or heads with especialy high ejection velocities or poor wave propogation control.
Gus
Hey Chris,
I may not have described the scenario very well. I understand pressure differentials, but for simplicity sake, I use the term vacumn instead of low pressure area. Also invision these two power jets adjacent to the slide one above the other(aprox 1/3 and 2/3 bore) Both of the side power jets are fed from a hard tube circuit into the float bowl.
So, we have three pressure sources(orifaces) all tied together. As the slide is barely raised(maybe 1/4 throttle) the open(1/2 turn) lower power jet is exposed to the air stream first and the low pressure scenario. The open(three turns) mid power jet doesn't see the velocity or low pressure yet so it may still be at the same pressure as the float bowls. If so, it may be easier for the air to be displaced than the fluid sitting at a lower elevation?
Whew! That was a hard way of saying what I was wondering.
Not sure about the rest of your theory, regarding saturation or effects on the motor.
