Thanks Tobyshepherd22 I agree with you 100%. Especially about the 95% rotation. My problem was when I was to that 95% point, the helix was as far as it could go. The helix was flat up against the clutch. It was impossible for it to go any further. The first clutch I did worked out, but not this one. Both are identical. I tried at least 15 times to get this right. Only by accident did I get this to work, and I know it's not the preferred way!! I had the helix in the vise and put the clutch down on the helix. Put my belt around the sheaves and rotated the clutch as hard as I could. As luck would have it the clutch came loose and fell about 40"and hit the concrete floor. The helix popped out and I tried again to get the helix back in. It did finally go in, even though it was not easy, but I did get it to go in. I hope I did not damage the housing. I do not see any nicks or cracks in the housing. And no this is not a BS story. I have to believe the snap ring washer has to have something to do with it because it does push those rubber rollers down farther, I do believe.
50-99 TSS-04 TEAM Clutch 2.95
The SLP Helix/Spring Shim will help maintain peak RPM riding at extreme
elevations (8,000 ft. and above). This shim spaces the hub of the clutch in
0.070" which raises the spring pre-load and rate by 8 to 10 pounds. It also
shortens the length of the initial (steeper) angle on a multi-angle helix
(ie. 58/38.46 with a shim would become a 58/38.40). This improves backshift
characteristics at high elevations in very steep conditions. It is
especially beneficial when using long, aggressive tracks.
