Go back a day or two and the actual numbers are given on one of the driveshaft threads. Lords 406 failure shear strength is 1980 psi at 180 degrees F. Making allowances for full stress reversals every revolution and the normal factors of safety, and the allowable working stress came to about 80 psi in shear. Unfortunately, the 2500 psi tension failure strength was accompanied with 30% elongation. Which means that one possible failure condition is that the steel fence post cap can pull out of the aluminum, causing stress concentrations in the aluminum at the corners, before the Lords 406 actually fails completely. It looks like the glue is normally slipping about .035 inches under normal belt tension loads from engine torque alone. Which is a lot. Throw in an "at rest belt tension" and you can add it to those numbers. It would seem that the glue slips, then the cap gets pushed back in, then slips again, then gets pushed back in again, etc. , until the glue just decides that it has had enough of this BS and the bond fails completely on either the aluminum or the steel surface. It looks like bond failure on the aluminum surface.
