I put the Bikeman on and it def. helps low end and noise level.Can you let us know if there is any change in the run-ability of your sled with the new can?
Gasket and sleeve is slid off your muffler and slid over diamond s and clamped together with bypass piece if that makes sense. I just held sliding sleeve just below gasket and used a flat screwdriver to gently pry to get gasket off. Mine was kindof stuck.I have a stupid question... So the pipe between the wastegate just gets slid back on with the no gasket just the clamp cranked down? ? kind of hokey for $800.
I'm following you. That gasket looked like it was pressed on. I just tapped mine off with a mallet.Gasket and sleeve is slid off your muffler and slid over diamond s and clamped together with bypass piece if that makes sense. I just held sliding sleeve just below gasket and used a flat screwdriver to gently pry to get gasket off. Mine was kindof stuck.
Yeah I used a big set of channel locks to squeeze it together and still have room to start the nut. The spring on the backside of the can was a bitch. I really could have used Rustydave's muscle and expertise on that one ? I think its all installed. Thanks for the help! Should be ready to go for next season!I was a little worried i was going to break it but once it loosened it just pulled off. The fun for me was getting that clamp squeezed back enough to get nut back on. Wish it was like theone on turbo
You are stretching the heck out of that spring. Hope it doesn't break or there goes belt. Are you done? Not sure if I'm done or not. Whopping 500 miles.Yeah I used a big set of channel locks to squeeze it together and still have room to start the nut. The spring on the backside of the can was a bitch. I really could have used Rustydave's muscle and expertise on that one ? I think its all installed. Thanks for the help! Should be ready to go for next season!
Forecast doesn't look favorable here. A turbo 165 it's not that fun to ride in spring snow and being that I didn't take the 155 I ordered, I don't have a spring sled to ride. My wife's sled is a Ski Doo 600 154 2.5". It's not nearly as cool as your wife's. ?You are stretching the heck out of that spring. Hope it doesn't break or there goes belt. Are you done? Not sure if I'm done or not. Whopping 500 miles.
I have always run 2 sleds. The wife's is the 3rd. I made the mistake of selling my 22 155 before the 155 Matryx showed up because the guy was hounding me to pick it up. Will never ever do that again. I will only sell one of my sleds when I have 3 in the shop. Had my boost went down I probably would have bee. The jack ass who bought someone's Khaos Boost for $25 k. This season was horrible anyway though. Probably the worst I can remember since I started riding in 2013.You are screwing up. You get your wife what you want to ride
Maybe but guessing between can hanging down and exhaust pressure it will be fine. Gap is in back Not frontLooks like a big gap from can to belly pan exit. Seams like alot of snow will get in there
I guess i never fought turbo. Pulled 4 springs and took hose clamp off. Plenty of wiggle and muffler comes right out. Did take darts out of intake that you wouldn't have to but it's easy and then lays out of way. Did second boost in half the time.
I was concerned with the gap also. Anyone have any issues with snow getting inside?I know the stock is like that also, just looked like more of a gap then stock in the picture
NoneI was concerned with the gap also. Anyone have any issues with snow getting inside?
