I bet that is awesome but not many want to buy a new clutch. I know Indy is coming out with weights pretty soon for the P22.
Has any one had any luck verifying the silber can is causing bog issues? How many of you are running bikeman kits with good or bad luck? I have a stage 2 kit from bikeman and a silber can ready to go on, but from what I’m hearing on here I better ditch the silber can. Were the DET issues with bikemans kit at lower or higher altitudes? This sled will run mostly from 8-10000 ft. It’s not worth it to me to install a product if most of the bugs aren’t worked out of it. I’ve ruined enough “deep” days with a sled that won’t run.
I can verify that on one sled with one can the silber caused a lot of problems.Just swapped my brothers sled back to stock can and run ability issues went away.
Silber can made bogs, blubbering and fouling plugs. (2-3 a day)
Just buy an aftermarket throttle block.Another follow up, ran the bikeman tune on stage 2 with their can and clutching and it makes it a whole new beast. No detonation at all on pump fuel. It makes my khaos almost too much to handle! Never thought I’d say that but I find myself really trying to place my weight out over the bars to keep the front down in the trees. After coming over backwards the fifteenth time it starts getting old pretty quick! It’s definitely a handful!! P.S if Polaris engineers read this please fix the throttle stick issue. What a joke to have to constantly worry about the throttle sticking in deep snow!
What kind of track speed are you seeing with that setup?Highly recommend a kurts gear down on these boosts ! a bit pricy but you do get a spare belt. really wakes up the sled.
It makes the speedometer innacurate.What kind of track speed are you seeing with that setup?
