big chute turbo build
if you don't mind buying new studs, you can pull the header straight up after removing the nuts and studs off each side.
Does the oil drain out when the turbo comes off or do the lines stay hooked? Already know about changing over to bolts from studs on Turbo. Do the gaskets need to be replaced anywhere with this?
NO oil drained on mine just a bit of coolant, need a new gasket between turbo and downpipe
Just the turbo outlet gasket. If you use a good up pipe (like ours:face-icon-small-win), you can use the Z1 turbo outlet gasket which is metal and reuseable. The problem with the factory pipe is it has a very thin flange and is not very uniform so they need a graphite type gasket to seal it on the 1100T
I'm not doing anything with my turbo this year. I just want to know if I need to remove anything to get on the turbo blanket and header blanket?
All you need to do is remove the intercooler and then remove the three heat shields and then put on the blankets. You can do it with everything else together. I had my BC turbo installed and then got the blankets and got them on just fine just took a little patience. ImageUploadedByTapatalk1349134447.758612.jpg
While doing the BRV kit last night, I see that there is a second 1/8" barb on the bottom of the BRV solenoid. The upper is tied to intercooler, the lower is open to atmosphere.
Could it be used for a boost gauge outlet?
All you need to do is remove the intercooler and then remove the three heat shields and then put on the blankets. You can do it with everything else together. I had my BC turbo installed and then got the blankets and got them on just fine just took a little patience. View attachment 181690
I bet you took the waffle pan off the bottom while the manifold and/or turbo was off though. That seems to be the biggest PIA of the whole job!
Yes I did but I was looking at it the other night and you should still beable to get it off. Just a pain in the a$$!
The couple of you that have installed the turbo blanket, where are you attaching both springs? Looking straight at the turbo from the front end i can attach my right spring to the right side mount on the blanket but the left side spring as no mount to go to, you just attaching to turbo?
Fuel consumption
It is exactly the same thing I found out on my TApex. If you do 30km of trail in and out and heavy upper/wo throttle stuff all day for 30-40 km it will use a little more. 50km trail and 20km on the hill it would be the same or less than stock. On trail it's more efficient with its power.
I wouldn't carry fuel on anything less than 80km days where we ride with that kit, or even the SC kit I will have. I rarely use more than 2/3 of a tank when filling at the end of the day even thou the gauge flashed fuel the last half of the day. I had a guy tell me this week who has 1800 miles on his that some days he doesn't use anymore than his buddies Etec. He has a BD2.0 (bc275 to come:face-icon-small-win). It's very good but will be determined on trail vs hill km where you ride.
Did you have problems with running out of fuel when going up and down steep grades when under half a tank.
I never did, nor the other 3 1100's i ride with. Maybe we weren't low enough on gas? Although I read where guys had issues even from almost full tank which doesn't seem like it could be related.
