509 Aviators......no fan needed![]()
X2 I agree best Google ever!!
. So I emailed 509 yesterday, they informed me that the only way the posts work is if you set the fan off center. As for the advertised "redesign" it meant they replaced the arched bridge with a flat bridge to allow the fan to breath (space between goggle and helmet brow). A minimal change at best!
Does Habervison make helmet specific goggles?
I haven't found polarization to be a benefit in flat light, very helpful on bright days though. Maybe just my eyes?
Does everyone's eyes acclimate to the colored lenses, by that I mean, I put on the yellow goggles and for the first few minutes everything is bright and yellow, within a few minutes it appears to be a light brown and the perceived brightness is gone. Does that happen to everyone, or an idiosyncrasy of mine?
I have three pair of scott's (87's I think?) I know they range from 5-10 years old. never have a problem with fogging.
The key is how they fit your helmet and what you use to deflect your breath away from them. You have to have a good seal around the bridge of your nose and your cheeks. It also needs to direct your breath out the bottom.
Get that right and it doesnt matter what goggles you use. Eric
Ok, this IS the key, I have had the same goggles, helmet and breath box since 2003. My goggles have never fogged, I'm dreading the day I have to buy new equipment.
I think you nailed it !!
My helmet is well vented, o'neal 3-series ( same exact helmet as the 509 ), I ride hard, I'm never cold and do sweat after a bit of hard riding. I can't breath out of my nose very well and a breathbox just makes me hotter. I tryed on my Scott XI's last night and noticed that the extra cheek foam makes them sit loose around my nose, my old 89x dirtbike goggles fit the face better so I ordered a vented antifog lens for those. That was 15.00 if that fails then I'm on to the haber's later in the year.
I have also invested in Klims agressor moisture wicking base layer and the summit tech long sleeve to try to keep the humidity level down inside the riding gear and maybe help to regulate heat better. Most of my old base layer was cotton or cotton / poly blend and did not dry quickly at all.
How many days a year do you ride?
Obviously (from this thread) not everyone else is that lucky. Some people sled harder, some sweat more and some (like me) don't breath well through their nose. It's easy to say that you need a google that fits your face and helmet and has good optics, but it's another thing to actually find that.
Every Saturday, usually from early December to late April 95 percent off trail. Until the setup I have now I did have fogging problems.
The main thing you see is that no two heads/faces are shaped a like and therefore, no single goggle will work for every single person.
