M5 suggested the 38mm Airstryker because thays what Ron uses for the Pulsed 500. Has to be the Airstryker. If you go pulse another thing to think of is frame. With the steel frame 500 the 38mm from a YZ250 (some KX and Suz use the same carb) can be used. You just have to block the TPS hole. This carb is 1/2" shorter than a regular PWK 38mm. This works good if you have a heat flange. I use the YZ carb in the winter and a sep PWK in the summer.
I suggest u call Ron and talk with him. He is quite the character and loves 2 strokes ! He will inform u on the
pulse.
pulse.
