Here is what we have been installing. Rider weight will have some effect.
8000'-10,000'
Stock 2013 & 2014 belt drive 155 & 163
Primary 140-330(stock spring) 61 gram lightning weights
Secondary 120-200 (7043152)secondary spring 54/34-.46ER helix
Stock 2011-2014 chain drive 155-163
Primary 140-330(stock spring) 61-63 gram lightning weights
Secondary 120-200(7043152) secondary spring 46-32F ER
Gearing 19-46
Each set up requires the use of Green/White ex.valve springs (polaris 7041786-03)
Proper clutch alignment and belt deflection
11.5" center to center
Belt to sheave clearance of .020"-.040"
A sacked out primary will drop running RPM by 200.
Make sure your motor mounts are in good shape.
If you have a motor that needs internal attention, it will have runability issues with these kits.
Weak motors cannot sustain a constant power band load.
The $28 upgrade is a must when loading the motor with this clutching. Consistently being in the powerband builds heat.
TRS: What RPM are you looking at with your clutching? I know that some people in sweden are blowing engines when beeing at 7800 rpm for too long... is it the powerband?
TRS, have you tryed this clutching at 2500'- 4500'? What do you think would work good for this elevation. Btw. My primary looks like the one that needs help lol. Belt only going about 2" from top of primary.
TRS- Care to take a stab at a TIED setup for an '11 pro 155?
Current: LR800 with carls clutching (stock primary spring, re-angled sheaves, 60-40-40 and gold/black sec. spring), AC powerclaw track, 62g, stock gearing but unsure if the drivers diameter are different for the Cat track.
So far some have said a red/black sec. spring with 73-55-.36 helix. I cannot find that helix on short notice but i have a 73-57-.46 i will try.
I am 220+gear riding up to 8500'.
8000'-10,000'
Gearing 19-46
