I was using a laser temp gun and found some weird numbers today.
Edit: I'm running MDS weights, I recently removed tip weight in search of more peak RPMs under load. Removing the weight seems to have done little (50 RPM gain) to nothing to increase RPM under load, but it pulls 82-8300 easily on the trail now (but lost ~6 mph on trail).
I was seeing ~140*F belt temps, ~170-180* primary-clutch face temps in the pow.
For comparison, the XM I was riding with was ~160-170* belt, ~200* clutch. So my temps seem pretty fair fin the pow.
On the trail ride to the truck I felt as if there was a heavy load on the engine, or some sort of 'drag' in the drivetrain. I thought my hifax may have gotten hot/sticky, but air temp was ~20-25* and I was running scratchers, even stopped an checked hifax, they weren't the problem.
I got back to the truck and checked temps; ~180* belt, ~220* clutch.
XM trail temps were much lower, (as you'd expect) ~140-150* belt, ~170-180 clutch.
Anything common to check? I just looked at spring and ramps/weights in the primary, they looked good/no issues. Could anything in 2ndary cause this?
Since I've owned the sled, the brake has been noisy (on the trail/higher speeds [40mph+]), like its every so slightly ON. It is also very hard to enable the parking brake. (I've actually seen others mention the 'hard to engage p-brake', and noise from the brake when moving.) Fluid levels look right. Is there a way to adjust brake pads? Any suggestions? I really feel its a brake issue, but don't know how to fix this.
If anyone has checked brake disc/pad temps, mine were ~140* disc, and ~175* pads. Again, just after a long trail ride to the truck. Little brake usage. Seems like those temps may be a bit high, but only thing I had to compare to was an XM and its brake disc is in the footwell, so I'd expect it to be much cooler, temp was ~40*.
I recently adjusted chain (chaincase) tension; finger tight, backed-off 1/4 turn. I plan to recheck that. But I still feel brake is culprit.
