That does absolutely nothing to fix the issue you had before so from the first pull its going be tick tock until it goes down again just like the engine you had. Going the cheap route to get you back on the snow without addressing why you had the failures in the first place isnt getting you anywhere long term.
The IQ chassis is great but the engines are junk which is why mine has a 910 Carls engine it it. The only way i will ride it is with the old big block based engines in it.
Guess I don't know what to do if my only option is a $3500 motor to make this thing last then I'm screwed. There has to be something else I can do to make this a reliable sled then putting a Indy Dan motor in it (no offense to Indy dan if i had the money i would buy his motor). What about buying a new crank and mono jug and then putting the PMS fix kit in it?
