Where are the outer drivers? I dont see them popping through the window?
The outer drivers ( L&R) engage on the nubs on the inside of the track- you won't see them in a stock configuration - They DO NOT drive on the window opening
Here is where you should be and in all reality- you can run WITHOUT the center driver- it engages on nothing- and pull them when we run aftermarket.
Mind you this pic is on a 2.6 w/ 8 tooth-/ Did not have a 3" in the shop to post this- but same center for a visual..
S/C
I agree, sounds like a loose track. If you pick up the back of the sled, does the track hang down 4"?Run your track a little tighter.
http://www.snowest.com/forum/attachment.php?attachmentid=266555&stc=1&d=1455555603
A new drive shaft doesn't fix the issue. This is how mine looks after a new drive shaft and 120 miles. Taking it back to the dealer for this on going problem and I also found a crack in my cylinder.
What did they find? My track is also running to the left. It is 1/8" from the tunnel on left side and at least a half inch from the tunnel on the right side. Alignment at the rear seems fine. Tension is set per spec. Center driver is running on the edge of the track window like yours.
