axys sks 3" track swap?
Is the chaincase in the same place as the rmk? If so its avid 7 tooth drivers, trim the rails, and an anti stab kit. Works great. I took the 163 2.6 off mine and put a 174 3.0. I took off the stock belt drive and did the tki. Not really sure what's unique about the SKS.
Sks has a front cooler. The main issue is with track clearance, even with 7tooth drivers.
SMF.... How much clearance though??
Exactly the same.
The non cooler tunnel front extrusion have ribs running across them at bolt points. (Bolts in each end)
The cooler fills the area between them on the sks.
My 16 162x3 has 1.25” in front of the track.
The tightest spot is on top at 7/8” to the front edge of the strip coolers.
