it can work yes but truly not as good as the 183.
Have you tried the gates 45C4553?
My turbo got here at 4 pm today as promised by silber and we put it on in two hours. QUOTE]
2 things are gonna happen here-
1. Your gonna have a belt burner.
2. Your sled is gonna run like crap. This is directly related to the "let's slap in a turbo in under 2 hrs" idea.
Kit is fine. 2 hr install is not fine.
At the very least a complete disassembly of the clutches and rebuild/clean. This alone takes 2 hrs.
Just my opinion
Just my opinion
Not sure how you don't clean your clutches when you install the updated springs, weights etc. Though possible, Silber isn't really suggesting you install the kit as fast as you can nor are they claiming all the clutch work can be done in that infamous "two hour window".
My $0.02 is clutching is so sled dependent. The kit can get you close, but its not going to to always be dead on for every rider, condition, and machine.
In my experience, the stock helix is just too flat and the belt slips causing roastage. Have to swap to something steeper or be prepared to shell belts.
Just picked up a 183 belt from the dealer but it doesn't have the green sides that my current belt has???
Nope!
Why did your Axys have a 115 on it to begin with???
we need video
i'm running the gates carbon belt on my pro turbo
and really like it 600 hard miles on the first one
(plus $85 is nice too)
it seems to perform better than the 115 did
haven't tried the AC belt
only down side to the gates is when they go they
go into a hundred pieces
very messy
Out of the three turbos I have ridden this season the silber and BD are decent. However I liked the MTNTK the best. Was clean and ran smooth. Plus the tunnel cooler is a pretty cool idea for temp.[/QUOTET
Do they all feel the same for top end power?
What happens to the coolant line coming off of the throttle bodies? Does it just stay exposed where you remove the line from the head??
The line is removed from the throttle bodies.
The line now routes from the the head to the turbo the turbo and then from turbo to coolant tank.
