Only if you use TKI upper arms. I installed Riot spindles on my 2013 with Zbroz uppers for 2016 spindles on the 38 frt end 2 seasons ago. Had to put spacers on tie rod mount to clear lower control arm and trim the ski rubbers on back as they forced ski tips up too much. Been happy with the setup over the 2016 spindles. I have a 175 track with a turbo on this sled and it is a bit of a beast in the trees but the spindles helped along with the changes I made to rear skid.Riots are taller, similar to zrp raise, and top of spindle is pushed forward more.
Only come in 40" stance and at the time I needed 38 uppers that would clear the reservoir shocks I have. Only Zbroz made an upper a-arm to clear the older reservoir shocks to use the new style spindles. They unfortunately no longer make them. I can use Blast uppers if I change my shocks.What’s wrong with riot uppers?
what is TKI/riot setup?Twin rail - full elevate setup
Alpha rail - TKI/riot.
Spindles (Riot) and upper a-arms with a different caster angle then the stock uppers; the geometry works really well with the the Alpha rail. The Iceage spindles work also and lots of guys like them on the Alpha, but they were originally designed for twin rails and in my opinion work much better on a twin rail setup; its a more noticeable change. The TKI/riot setup was specifically designed for the Alpha and greatly improves the handling. Some can't get over the looks of the riot spindles, but if the setup improves the handling then that is what is important, not the damn looks.what is TKI/riot setup?
is this for the rail or the spindles?
so where do you get riot spindles? and what is TKI involvement in this equation? thanks for the reply, im startSpindles (Riot) and upper a-arms with a different caster angle then the stock uppers; the geometry works really well with the the Alpha rail. The Iceage spindles work also and lots of guys like them on the Alpha, but they were originally designed for twin rails and in my opinion work much better on a twin rail setup; its a more noticeable change. The TKI/riot setup was specifically designed for the Alpha and greatly improves the handling. Some can't get over the looks of the riot spindles, but if the setup improves the handling then that is what is important, not the damn looks.![]()
You can order the full kit from TKI here - https://tkicnc.com/product/tki-upper-a-arms-for-arctic-cat-2018-2022/I think I have it figured out
riot spindles from the AC Riot model
then TKI rear scissor?
dot the riot spindle raise the sled as well?
