Turboxp is right
My 66 spools incredibly quick.
I am running higher boost than the two strokes will reliably handle but my engagement is now at 4000RPM and boost comes on lightning quick.
Just in my back yard at full throttle from a dead stop my sled is already at 13-14psi in one sled lengths time and the boost just keeps building up from there at the same constant rate.
The adjustment for the vanes is the wastegate plunger nipple that your small air line goes into from your airbox.
For adjustment:
Loosen up the lock nut and turn the entire assembly with the nipple counterclockwise until it no longer has pressure against the stainless actuator rod that is connected to the vanes. Then tighten the assembly 2 full turns in toward the turbo. This is a good starting point.
Mine is only tightened 1 and 3/4 turns in. Don't go less than 1 and 1/2 turns in because it holds in too much heat.
Each 1/4 turn makes a lot of difference in how quick it spools. If you turn the assembly in too far (like 2 and 1/2 turns) then the sled will go a long distance before the turbo builds up boost but the top end will have good power once it gets there.
This has all been explained on this forum before but it may be helpful for your situation.
Since you say that your sled has a one second delay in acceleration then there must be some adjustment to be done.
In about one second my sled is already moving past 15psi and I have a large volume intercooler and 2.5" charge tubes.
There is room for improvement on that sled of yours just keep dialing it in and don't look at the gauges too much when climbing, look ahead of you!
I know exactly what your talking about there
