ARE THERE ANY BALL BEARING APPLICATION SPECIALISTS OUT THERE?
mountainhorse
If you dont know but know someone who does... please chime in as well.
I'm looking for a bearing "guru" (tech sales) that can help me find a bearing part number.
I need a stainless steel, double sealed & greased (2rs), 1" bore, set-screw or eccentric locking collar, single row bearing with a 52mm outside diameter... OR a 2.5-3" outside diameter. NON radius bearing.
Any ideas???
Prelubed bearing 1" i.d. and 52mm o.d. Cyndrical o.d. NPC-100-RPC Spherical o.d. NPS-100-RPC
Relubricatable 1" i.d. and 52 mm o.d. Spherical o.d. only NPS-100-RRC
These are Timkin and the BCA numbers, hope this helps
:beer :beer;
Well MH..
Looking for a needle in a hay stack!
lol..
Your wanting a 6205 bearing with a lock collar.. just buy a lock collar extra..
like the RA100RRB 1" inside but is a radius bearing
i do some more digging.. and see if i can find it..
Hey MH, being a nautical tug boat guy I can get you some "Relative Bearing" grease if that helps. Been out of town. I'll give you a shout later tonight. EW
Good one modsler... yes, I have lost my bearings... more than I should...LOL
Can anyone tell me if this NPC-100-RPC bearing is stainless steel? I cant have it rusting... it is exposed the elements.
you might talk to mike a ve there should be a bearingexpert in his area i know a guy in the tricitys wa they used to go by oregon bearing when i was in the farming life
HAVE YOU TRYED A WATERPROOF GREESE AMS MAKES A GREAT ONE , I USE A SERINGE NEEDLE AND A ZERK SCREW THE ZERK INTO THE NEEDLE TIGHTEN IT UP PUSH INTO GUN HOSE, USE THE POINT TO GET UNDER THE LIP AND PACK AWAY
"Awww, come on guys, it's so simple maybe you need a refresher course. It's all ball bearings nowadays."
Sorry, I couldn't help myself.
oo Bearing Material is not stainless steel..
Sorry MH
