Anybody else have gauge fluctuation issues
Indy_500
Towards the end of last season my standard gauge on my 16 axys pro would fluctuate between temp, rpm, and mph (might be another one or 2 but can't think off the top of my head right now). Thinking about bringing it in for warranty but it won't do it for them as it is sporadic when it happens, but it happens enough it needs to get fixed. I did pull the cowling off to adjust TPS at the beginning of the year, maybe corroded or loose connection to the switch on the cowling or a bad switch? Anyone else?
While it is idling or when you are riding? Mine flickers when the sled is cold and then it goes away after warming up.
While riding. The gauge doesn't flicker on and off whatsoever, just switches between "modes" whenever it wants.
My gauge went off and on and high beams would not work. Dealer said it was a known and common issue with corrosion and fixed it. I would have that looked at.
Not that it seems like a common issue but i finally solved this issue and figured I'd share in case someone else runs into it. After disassembling every connection cleaning dilectric greasing them twice i never got it figured out. Turns out it was just a bad mode/set switch in my "console" on the switch panel by the gas cap.
