Any real world HP numbers for the HO engine?
Audio numbers announced during the dyno session, for those that watched it live yesterday.
151 Stock
156 With SSI pipe mod (speedshopinc)
160HP with SLP pipe system
^All of those runs were in ethanol mode, they didn't realize until 3/4 the way through testing that when you have the hood off it automatically goes into ethanol mode, with the gauge cluster plugged back in it made 156hp stock. 160+ with different pipes.
156 /160 H.P.
The truth is they set the Dash gauge for NON-ETHANOL (3-4% leaner) mode, then disconnected wire plug when removing the hood thinking the computer would HOLD the non-ethanol setting,
later they found out it didn't hold, and the E.C.U. reverted back to the safer/richer ethanol setting.
To clarify the 160 H.P./156 H.P. now on the same sled
160 H.P. Dyno run, fuel tested there had 0% ethanol in it
156 H.P. Dyno Run , fuel tested to be 5% Ethanol
No conspiracies, no modified E.C.U's...............
Any if you're thinking of buying a pipe or silencer, a $25.00 annual subscription to Dynotech research provides a wealth of information
