Went to the powder coaters the other day, and his compressor went down, so the tunnel and rails are still waiting to get done...checked back again today...no progress...starting to get VERY irrated
hoping to have the engine and wiring installed within 2 weeks...will be picking up the billet front crossmember from a friend at the Puyallup Snow Show this weekend...and motor can be installed...along with some wiring to test fitment/routing issues...
got bored so messed with some stuff today..
installed the coils on the ECU bracket since the RAW hoop doesnt have the holding bracket...this also lets me keep the shorter plug wires, and will still be able to reach the plugs no problem...removed the exhuast solenoid from the coil bracket, bring the coils closer together for a cleaner look...YES, i will keep the exhaust valve solenoid and it will be plugged in the harness and tucked away, as the ex. valve will be plugged on the engine as is my other 900..
i have a belt cover for the RAW chassis that i will be using, i will mount the Capacitor on that since i put the coils where the cap goes...
i also ran some ground wires from the coils, to the ECU, and from the ECU to the chassis, and a ground wire from the VR to the chassis...the dragons were having ground issues, and this seems to be a great idea anyways..so might as well hook it up to be safe...
****also note, those with the 06 700/900...the way the VR is mounted from the factory, the VR wires will rub againist the fuel tank, they are literally smahsed together...and will eventually rub through the insulation and cause a major issue...if you look at how i mounted my VR, i rotated the bottom of the VR FWD, and this put the VR straight up and down...drill a new bottom hole, and mount the VR there...it gives the wiring ALOT more room, and they are no longer pressed againist the tank****
installed an 09 dragon coolant bottle to get rid of the "plug" you have to do when removing the front radiator...much cleaner
also powder coated my MAG side running board cooling tube, and mounted it againist the modified footwell section...looks pretty slick i think...
not much of an update...but about all i can until i get the new bearing kit from WPS (All Ballz Bearings) for the jackshaft/chaincase/driveshaft, and install the engine, and rear tunnel section and skid...
then i will be able to set it down as a roller and mess with the front end, plastic and adjust any fitment issues from there on...
