M
ManUtdWY
My experience is that it is a completely different solution from a full size RV Suburban heater. Those are higher BTU rated and made for quick heat. These diesel air heaters are more of a sustained heat solution. Would it help the furnace heat up the space more? Sure, but probably not really noticeable. I imagine if you put both in your trailer, that your more typical use would be to fire them both up to heat the space and then turn off the furnace and let the diesel heater keep the chill off over the long period if that is what you are after. I intend to install a second one in my trailer to run along side the one I've already installed for the coldest of days.How would you compare the heater to a full size rv suburban heater as in heat output?
Thinking this heater may enough to help warm the trailer up faster.
