I come back to my original thought, what are all these header builders using for material and what is the application? I don't know but I'm willing to bet its either 304 or ideally 321 16G. The cast headers aka Ulmer or whatever they are now have a pretty good rep or so it seems mostly because a cast unit has the meat, so again JMO it stands to reason that if you use a beefier material like Impulse then one would think that it should last better. Again IMO you can't compare a 16g header (which when you put the caliper on it is pretty thin piece <0.65") to a cast unit because the cast unit will be inherently inefficient but last forever because of its mass like a turbo diesel truck manifold which we are all driving. Why aren't they always cracking? Cause they are over engineered not to by being large enough to take the heat. If you go to the Burns stainless site they have some pretty good info on building turbo headers etc but they don't ever say this is for your daily driver. They sell 321 SS 16G stuff mostly for race apps. The Impulse setup gives you a pretty decent compromise with good flow and durability/beef also in 321 which is the only real option aside from Inconel. There's good weight and bad weight on a sled especially a Yami. Reverse is good weight and so is a beefy header. JMO. I know what I would do.
M5
The Impulse website states that the shorty header is constructed of 321 stainless that is 3/16" THICK. MUCH thicker than 16 gauge.
