Unless it’s a Speedwerks, slp or other stage kit with advanced timing, fuel controller, porting of head mods. Lots of info on different threads on this forum.
That is correct, but those aren't stock sleds either.
Kinda late to the show here, but after 6 pages and nobody has said you guys are nuts for not running an A/F gauge.?.?
I’m not a huge knowledgeable turbo guy, but for a 2 stroke turbo you have 3 steps, which step 2+3 get repeated till she’s dialled.
1. Boost (whatever the end user wants 5-10)
2. A/F mixture (11.5-12.3, 11.8 being magic)
3. Clutching
That A/F gauge will tell you if you are too fat on a hard WOT pull, 10 seconds or longer. If your richer than 11.5 on WOT, you may have big problems down low, and I don’t think it would be turbo related.
Lots of people told me to call Colon from cycles and sleds. Well I did and bought there full kit and sled ran so much better. So glad i called them. No bog, no lag, and power for days. Lets hope it stays that way thru the rest of the season
Sent from my SM-N950U using Tapatalk
I sprung for the full kit. Primary and secondary springs, weights, bov, boost t and gauge. Cost was $1,100.What does the kit consist of and how much?
The kit was magnetic inserts. Empty they are 68 or 70 grams. Can load up to 90 I think. I ride from 8000 to 12000 I'm using 76grams right now. Just turned yo the boost and was told I could get 8600 rpmsWhat weights did he send in the kit?
According to Justin as of yesterday. New map coming in the next 2 weeks...
Ill believe that when I see it, since he's been saying that for almost 6 weeks now.
So that primary spring change still working out for softening the bottom end feel?
